TwinTurbo.NET: Nissan 300ZX forum - Misfire all the time or under certain conditions?
TTZ2NV(EPTmotorsports)
on June 18, 2013 at 10:09 AM
Misfire, stuttering issues
posted by Carlos Ramirez
on June 18, 2013 at 09:14 AM
Which cylinder is not firing? Check compression.
Carlos Ramirez
09:14:37 06/18/13
Vacuum/boost leaks? Can you explain your misfire in greater
TriniTT
09:17:31 06/18/13
Misfire all the time or under certain conditions? -
10:09:42 06/18/13
Re: Misfire, stuttering issues
Carlos Ramirez
10:29:55 06/18/13
Injector? (n/m)
ChaseGrayTT
10:51:41 06/18/13
maybe? But they ohmd out correctly (n/m)
Carlos Ramirez
11:04:07 06/18/13
Could be clogged.
ChaseGrayTT
13:45:54 06/18/13
Which plugs and how many miles on them? (n/m)
MixManMash
10:49:02 06/18/13
had NGK BKR7eix in there put some ZFR7f-11 in for now
Carlos Ramirez
11:05:42 06/18/13
gap and boost level ? (n/m)
ZWolf
11:22:37 06/18/13
I'd swap in and test with a known good CAS if you haven't .. (n/m)
SniPer (SR-71)
12:06:30 06/18/13
don't have one :-) I have thought of that
Carlos Ramirez
12:23:09 06/18/13
CAS connector clean & seated correctly? (n/m)
vorpalZ
15:44:14 06/18/13
Sounds like a connector issue, I'd check maf/temp sensor. (n/m)
TriniTT
13:20:10 06/18/13
^this. I fought a random misfire for a while
Lumpydonut
14:17:39 06/18/13
these are all helpful hints
300ZMang
18:52:47 06/18/13
update
Carlos Ramirez
21:34:19 06/18/13
I have a few spare parts I can let you borrow
90GoldZ
00:50:08 06/19/13
thank you sent an email (n/m)
Carlos Ramirez
14:25:24 06/19/13
updated 6-20
Carlos Ramirez
20:14:34 06/20/13
